Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage- und Fehlerdiagnose-Informationen für die 4. Generation des Apple iPad mit GSM 4G LTE-Mobilfunknetz (AT&T), erhältlich mit 16, 32, 64 oder 128 GB Speicherplatz. Veröffentlicht im November 2012. Identifiziert durch die Modellnummer A1459.
Locked on white Apple loop after restore
So I've tried to download the IPSW and install under DFU mode, no success.
I've tried to plug in the phone jack as suggested in another post, no success.
I've also tried the hairdryer trick to heat up the SIM chip tray aperture that was mentioned somewhere else, still wouldn't work.
And of course I tried different cables and different USB ports - I had used the same cable and USB port to restore my iPhone minutes early to check that everything was fine and it was.
Nothing worked, iPad remains stuck at about 75% and show error 50 when recovering… Could it be some hardware issue and if so, how to fix it…?
Update (03/07/2018)
Gave up, will sell it for parts...
Any way of figuring out the capacity (Gb) with the serial number?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
try to use a different computer
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Carlos Ferrari wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 313
