Using Suction Cup to remove screen with a screen protector
Can you still use the suction cup to lift up the screen if you have a glass screen protector (ZAGG) installed on the screen or will it lift off the protector?
Ist dies eine gute Frage?
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
You can use suction cups no problem but on cracked screens the glass tends to separate from the palstic frame if it is an after market screen.
I always use razor blade on sides of screen to lift it up after taking out the two pentalobe screws.
Brian, you can use a suction cup to remove the screen. The screen protector won't come off
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 27
Insgesamt: 1,735
Thanks for the answer. Worked like a charm. Battery replaced in about 20 minutes
von Brian Thompson
