Zum Hauptinhalt wechseln
Dieser 12-Zoll-Laptop wurde Mitte 2006 auf den Markt gebracht und galt als gut ausgestattet, leistungsstark und ultraportabel.
When I connect the laptop to the power it does not power on or charge
when i connect the laptop to the power ,does not power on or charge, the laptop work fine when the battery was have charge, but later stop work the power adapter, and i check the adapter and is does have power, what can be the problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
A very good chance that the jack/socket that your power adapter plugs into is loose or faulty. The easy test for this: Make sure your power adapter has electricity. Plug your power adapter into the jack on the laptop. While watching the power/charger indicator lights gently move the adapter's plug in the jack. If you can get either light to flicker or stay on the problem is the adapter jack/socket on the lap top. Not many people have the skills to replace this themselves. You may want to take it to a repair shop. If you believe this is a job you can tackle here is the part for a reasonable price.
http://www.amazon.com/OEM-POWER-M1210-M1...
Here is Dell's online service Manual for your laptop.
http://support.dell.com/support/edocs/sy...
War diese Antwort hilfreich?
Bewertung 7
Antwort hinzufügen
kitozo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 2,485
