Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
What's the difference OEM VS OEM-compliant
So I was reading around a bit here and someone mentioned etrades, so I looked them up and found the iPhone 7 LCD screen / digitizer there and I see a bunch of different grades the highest is an S+ for for $81 and an S for $64 I'm trying to save a few bucks so I'm wondering is the S+ Necessary ? The only difference is glass and flex cable OEM and OEM-compliant, what's the difference between those 2?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
  • OEM Flexes are thicker and more resistant to tears and have better quality soldering for the connectors.
  • OEM glass will be stronger and less brittle. OEM LCD's will have better colour response, viewing angles etc.
  • Most importantly, you want a cold pressed glued (CPG) versus hot press glued screens as they will last longer before the glass separates from the frame.
You have to read between the lines on most of these vendor websites. They use words that normally mean high quality but in a context that means anything but. OEM is original equipment manufacturer. That means that whoever builds an actual part for Apple products. They have certain quality specs to achieve in order for the lots to be approved. If they are also manufacturing similar parts, they could claim to be OEM parts but they might not meet the same specs.
Everything has a price, you just have to pick based on your needs.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Ahh gr8 Ok thanx for the info !
von
And many Claims OEM for non OEM Chinese knock off that cost under $20 wholesale.
Have them send a picture of the Apple logo on the cable
von
Antwort hinzufügen
chris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,879
