Zum Hauptinhalt wechseln
Der Mac Pro (Anfang 2009) kam im März 2009 auf den Markt. Er führte erstmals die Nehalem Architektur von Intel in die professionelle Apple Desktop Reihe ein, und verfügt über ein leicht neu konzipiertes Inneres, das auch bei den 2010 und 2012 CPU Updates beibehalten wurde.
199 Fragen Alle anzeigen
3 Ram Slots not working after 5,1 upgrade and processor install
Mar 31, 2018
Maybe you can help. I did this upgrade on MacPro 4, 1-Did the firmware upgrade to 5,1. Completed the hardware install as listed above with 3.33 ghz processor. Started it up and only one of the Ram in working. Red LEDS on next to the back 3 ram slots. Switched around the Ram (although they are all the same for both the 4,1 & 5,1 models) to no avail. So I have only the #1 Ram slot working. Did the Pram reset a number of times. Did I screw up the board plane? Is that possible? I was extremely careful. Any thoughts on this would be appreciated.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Any ideas @mayer ??
von
How did you do the EFI update? With what software? What was the operating system you were using and did you upgrade it? Exact what year model do you have and what processors are you running?
von
Einen Kommentar hinzufügen
1 Antwort
The EFI update went fine. Did the SIP disable in El Capitan in a Mac Pro 4,1-
Result 5,1. Fine.
Figured out the cause. One of the very, very tiny pins for some reason got bent on the periphery of the center of the CPU (on the processor tray). I was very careful- So I can not for the life of me figure out how this happened. After attempting to straighten the pin and booting up I got only 1 RAM slot not working. 3 is much better than 1 working. I took it apart about 4 times and I got the same result.
They are very fragile and so small- I needed a jeweler's loupe to do the job.
I didn't want to chance it another time.
It being a back up Mac Pro- I'm accepting this problem. Bought more RAM - so I making up for the lost slot.
Thanks for your answer.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Paolo Alberto wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 840
