Zum Hauptinhalt wechseln
Der Mac Pro (Anfang 2009) kam im März 2009 auf den Markt. Er führte erstmals die Nehalem Architektur von Intel in die professionelle Apple Desktop Reihe ein, und verfügt über ein leicht neu konzipiertes Inneres, das auch bei den 2010 und 2012 CPU Updates beibehalten wurde.
200 Fragen Alle anzeigen
No iPad connection with Logic remote app
No iPad connection with Logic remote with OS-X El Capitan 10.11.6 and Logic Pro X 10.2.4
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Per Apples spec sheet: Logic Pro X it requires MacOS 10.12 or later, as such 10.11.6 El Capitan is not supported in this release.
If you have a cheese grater Mac Pro you'll need to upgrade it so it can run a newer version of MacOS.
In addition make sure you have the supported iOS device as listed here: To use Logic Remote, you need an iPhone 6s, iPad Pro, iPad (5th generation), iPad Air 2, iPad mini 4, or later with iOS 11.
I do believe it requires both Bluetooth and WiFi to work as well so make sure both wireless services are working on your system and you may need a newer AirPort board as well (802.11ac)
War diese Antwort hilfreich?
Bewertung 2
7 Kommentare:
Hi Dan,
Thanks for the quick response and solutions! It seems that I have to invest one more time in a new Mac.
von
@rockwood for what it's worth, you can upgrade a 2009 Mac Pro to run 10.12 and even 10.13 with almost no effort, it just requires flashing the firmware. Here's the guide: Aktualisieren der Firmware von einem 2009 Mac Pro 4,1
von
Thanks @josh for adding the firmware upgrade guide!
von
@rockwood - Rob I don't think its that dire! I'm sure you can get your systems firmware updated. Getting up to Sierra should be easy. I would stop there for now.
von
Hello Dan and Josh,
I did update the firmware and now i can get the High Sierra update in the appstore, but now it says: You dont have enough memory to install High Sierra! But i do!
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
rob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,129
