Zum Hauptinhalt wechseln
The Olympus Stylus 1010 is a 10.1 MP digital camera with 7x optical dual image stabilized zoom. It has a 14.7 MB XD-Picture Card. The camera is 99 x 56 x 25 mm and weighs 136 grams.
usual SD card will not go in slot.Could something be blocking?
I have successfully used the card before now it only goes into the slot halfway. I do not see anything in the slot
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try rotating the card 180 degrees and inserting it. It will only go in one way.
War diese Antwort hilfreich?
Bewertung 5
I have the same issue, it's not the way the card goes in.
I got it from a pawn shop. Can't tell if there is an old card broken inside, or if the popup housing might be broken.
Bewertung 0
Antwort hinzufügen
Ellie Ramirez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 469
