Why di I have to hold the signal light lever to make turn lights work?
Have to hold signal light lever so the signal lights will work. The lever does not lock in place. 1989 F-250 Ford Lariat
Ist dies eine gute Frage?
bfortune there should be a plastic 'trip' part that gets set when the indicator lever is is pulled up or down. This sets a tripping part that is contacted by a steering shaft projection (canceller) to trip the turn signal off when the steering wheel goes straight. Take a look on here as well as on here for a better understanding and how to possibly fix it. Instead of trying to fix it you can of course replace the whole assembly as well.
War diese Antwort hilfreich?
Here is a YouTube video on how to change the Turn Signal Switch. You can view my complete channel which contains a Playlist dedicated to the restoration of a 1991 F250 4x4 7.3 IDI Pickup.
https://youtu.be/ZKlkU0iOrw0?si=-ELGD8Wm...
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 740
1 Kommentar
Know what to do now. Great help. Thanks
von bfortune
