iPhone X automatic brightness adjustment failure
IPhone X cannot automatically adjust brightness after changing the screen
Ist dies eine gute Frage?
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
Hi,
This is a new issue a few of us have brought up and we are investigating, this also appears to be an issue with the iPhone 8 and 8 Plus.
This is also an issue I have on my personal X.
I replaced my cracked screen with an original screen pulled from another X, and the ALS (Ambient Light Sensor, responsible for auto brightness etc.) no longer works, myself and a few others have also noticed that the brightness also isn’t as bright as it used to be overall.
If you put on your original screen, the ALS works again we have found.
So this is definitely to do with the screen being replaced and not user fault.
When we have an idea how to fix this, we will update accordingly.
Just an FYI for replacing Iphone 8 and X Screens
https://www.engadget.com/2018/04/11/ipho...
TL:DR
The short: Apple is automatically disabling the ALS and only Apple or authorized phone repairer's with the Horizon Machine will be able to fix the issue.
If you replace iPhone 8, 8 plus or X screen you need to copy the firmware data of the original screen into the new screen. The needed tool is under development. I saw some working versions, what are tested and working with IOS 11.4 and 12.0 Beta. The screen data can be cloned only to OEM screens for now.
Afte the copy of the data, the light sensor works well again.
If you would like to know more about this problem read this article: http://www.futuresupplier.com/blog/solve...
If you need an ALS box, you can order here: http://www.futuresupplier.com/iphone-8-8...
Kommentare:
Szia Laszlo Bohm, bocsanat, hogy igy ismeretlenul zavarlak! Volna-e tobb informaciod ezzel a problemaval kapcsolatban, mert lenne par kerdesunk es hatha tudsz nekunk segiteni. Elore is koszonom!
von Anita Nagy
Szia Anita. Az emlitett eszkozzel nem dolgoztam, csak a munkahelyemen kaptam rola informaciot. A fejleszto ceg az egyik beszallitonk. Mi lenne a kerdesed?
von Laszlo Bohm
Szia Laszlo! Koszi a valaszod! Azt szerettem volna kideriteni, hogy az a szukseges adat csak a kijelzoben van, vagy esetleg magaban a telefonban is, mert pl ha az eredeti kijelzo teljesen ossze van torve es az adat nem olvashato ki belole, akkor lehet-e tenni valamit, hogy a szenzor mukodjon az uj kijelzovel is?
von Anita Nagy
Szia. Elmeletileg ha egy masik mukodo kepernyobol kiolvasod az adatokat azt is fel tudod hasznalni az uj kepernyohoz. Tehat ha a tied nem mukodik probalj szerezni egy mukodot es annak az adataival ird ujra az uj kepernyot. A gyakorlatban ezt nem probaltam, de olvastam kommentben hogy valaki igy oldotta meg ezt a problemat. Remelem nalad is mukodni fog.
von Laszlo Bohm
Szia Laszlo Bohm. Egy olyan kerdessel fordulnek hozzad hogy van egy saját iphone x-em és törött a képernyője viszont van egy eredeti teljes kijelzőm szenzorokkal meg a hangszóróval együtt és ha azt úgy együtt kicserélem a programátor segîtségével akkor utána is ugyan úgy minden funkicó fog működni?(face id, fényérzékelő)
von zgyergyai
we have the solution to resolve such ALS issue.
https://www.youtube.com/watch?v=04OFEjRp...
this device will transit the data from the original cracked oled to the new replaced one
the procession only need 10-15s
Kommentare:
only need usd35
von christopher
Where can I buy this device?
von jaca
hi Jaca, can u send your email to chrisyao0616@gmail.com, will let you know more details
von christopher
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 31
Insgesamt: 4,657
