Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone turns on right after turning off
So I recently fixed a water damaged iPhone, fairly simple repair, just needed a new battery, screen and to reflow one of the touch ic chips (I know it is a bad practise, but I got this cheap damaged iphone just to get some experience on microsoldering and repairs in general).
The thing is, I have a quite wierd problem. Whenever I power off the iPhone, it turns off and right awat i turns back on again. It happens aswell when the battery is discharged, it keeps showing me the logo with the battery and the lightning cable.
The power butron is not faulty since the phone doesn’t lock or turns off by itself.
Can anyone give me a clue to why this is happening?
Thank you!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
did you ultrasonic clean the board and do a full inspection for corrosion. Your repair sounds like there is a battery /power problem that needs troubleshooting to start. Water damaged phones are finicky-
War diese Antwort hilfreich?
Bewertung 0
id be checking under a microscope around the top front section of the board or near the lock flex fpc . You'll likely find corrosion shorting the power flex or something on its circuit causing the phone to think your powering it on.
Bewertung 0
Antwort hinzufügen
rapiteu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 533
