Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2688 Fragen Alle anzeigen
Doesn’t turn on
Hi so I have a iPhone 6S, that recently got into a boot loop, and now it doesn’t even turn on. I tried doing a hard reset, replacing the battery, and when I plug it into iTunes it tells me to restore, and after clicking ok, the restoration process begins but it always stops and gives me error 15. I appreciate any help. Thanks.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
You sure it's error 15? I can't find any info on that (1015 however means your phone is jailbroken and permanently bricked)
von
Einen Kommentar hinzufügen
1 Antwort
I've worked on hours on iphones that have boot up issues and some can be cleared by connecting to iTunes and some can't. Its a software glitch that can't be repaired no mater if the battery is replaced screen or anthing else. At that time its time to replace the phone.
If you tried going into Recovery Mode the last resort is DFU Mode: I have attached an artctle that explains and also helps you to do that just click on the link.
https://www.ikream.com/2018/02/how-to-fi...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Luca wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 50
