Zum Hauptinhalt wechseln
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I have probably a similar issue. Who can find and change a battery here?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
War diese Antwort hilfreich?
Bewertung 3
I'm having the same problem. Have you fixed it?
Thanks!
Bewertung 1
2 Kommentare:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
von
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
von
Antwort hinzufügen
swat1230 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 23
Insgesamt: 2,640
