LG TV - Turns on with blacklight & menu visible but no actual pictur
Hello all,
This is concerning my LG television model 47LV4400-UA. It powers on (red standby light turns blue) and the menu appears on the screen, but there is no picture. “No signal” message on all inputs.
I tried all the HDMI ports and switching HDMI cables for the cable box. With the 2nd cable, the screen went solid pink but I think that was a faulty cable I had around. With the 3rd cable, a message “HDCP authorization failure. hdmi port is disabled” appeared over the picture, then “No Signal” returned after 10 seconds. I plugged in the original HDMI cable and reset the cable box. I again received the “HDMI port disabled” message as the cable box booted up, followed by the “No Signal” screen.
I also tried streaming video using my Chromecast and audio would play through the TV, but no picture. Reset the Chromecast, same problem. The next day, no audio or video.
Any thoughts on the possible issue? I unfortunately do not have another TV to test the devices on
Thanks for your time!
Ist dies eine gute Frage?
1 Kommentar
Hi @ayepes ,
You said that there is “No signal” message on all inputs", then just relate to HDMI.
Have you actually tried the other input types at all e.g. composite or component?
It may be if the others work that there is a problem with just the HDMI controller section of the TV.
Apologies if I am wrong about this and you did try all input types
von jayeff
