Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
787 Fragen Alle anzeigen
replacing shattered front glass
Hi, I am tasked with repairing a model with a totally shattered front glass. It was so bad that the suction cups would not work, I ended up having to chip it off one small piece at a time. Scraping/chipping the glass shards/glass dust from the edges was the worst. The good news is that it is done and the LCD looks good.
My question: As long as the edges are cleaned of excess adhesive and the LCD is ok, is the replacement glass offered from the iFixit store all that I need to complete the repair? I see that the adhesive is included, any trick to the application? Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would run through the guide at least three times before starting. Make sure the inside of the glass is clean and the camera is ready to attach. This is not an easy job and you will need uninterrupted time to do it. MacBook Pro (13 Zoll, Mitte 2010, Unibody) Displayglas tauschen
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I agree, although most of the work is already done. All that I need to do at this point is put the new glass on. I rad the instructions, but didn't see much regarding actually putting the new glass in place.
von
Antwort hinzufügen
support0 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,682
