The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
36 Fragen Alle anzeigen
Why doesn't my LG Stylo 3 plus pop up on my computer screen when conne
why doesn't my LG Stylo 3 plus pop up on my computer screen when connected with USB
Ist dies eine gute Frage?
Punktzahl 0
Kommentare:
Hi @steings ,
Have you tried a different cable or a different USB port in the computer?
Does the phone indicate that is is connected to the computer by showing that it is charging?
Have you checked the phone's USB port enclosure to see that it clear of any lint etc,. which may be preventing a good connection? (use a vacuum cleaner to suck out any debris as you don't want to damage the pins by using a metal probe etc., Use a wooden toothpick if necessary)
What have you tried?
von
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
1 Antwort
Most likely the phone is set to charge only mode, if you pull down your notification panel while it's connected you should see a notification saying it's in charge mode click on that and you can change it to MTP (media transfer protocol).
War diese Antwort hilfreich?
Punktzahl 0
Antwort hinzufügen
Stephen Steingass wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 136
