Zum Hauptinhalt wechseln
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
212 Fragen Alle anzeigen
Stops at spin cycle with UL
what do i need to fix if it stops on spin cycle with UL. its spins in one direction for couple seconds then stops n starts to spin in opposite direction...it does this back n forth over and over but never goes into spin cycle
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
4 Kommentare
My washer does that Ul code at the final spin the entire bucket moves uncontrollable the the ul codes appears
von
@Julie Cruz
What is the model number of the washer?
Bucket moving about might be a problem with the suspension rods.
knowing the full model number will help to find the correct part if they are faulty/broken etc.
von
Maytagz quiet series bravos 300
von
@Lee Hart
if it is the suspension rods that are the problem, knowing the model number will ensure that the correct parts are listed in an answer.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@benlogali9 the UL code is for Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
There are a few things that can cause this. Check the suspension kit of the drum to make sure that it is not excessively loose. Most commonly for this model is a failed rotor position sensor or a cracked stator on the motor. To check that, you will have to check the bottom on your washer. Make sure that the motor bolt is tight
The following images show how to get to those two parts.
You do want to consider posting some images with your question. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. It will allow us to see what you see.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Thank you! I hope to god this helps! I’ve leveled it and everything and it still beeps UL.
von
Antwort hinzufügen
Trista wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 35
Letzte 30 Tage: 196
Insgesamt: 42,118
