Zum Hauptinhalt wechseln
Der Game Boy kam am 21. April 1989 in Japan auf den Markt, dann am 31. Juli 1989 in Nordamerika und schließlich am 28. September 1990 in Europa. Er ist erkennbar an einem großen grauen Gehäuse und der Modellnummer DMG-01
68 Fragen Alle anzeigen
Crooked screen and missing center lines
I have an original game boy and recently I changed the body. I believe the problem existed before.
The screen appears to be not aligned with the body and in addition has two white lines in the center. What may be due?
Could it be the video connector? I have already tried to enter it several times but the screen remains not centered.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The vertical lines are most likely due to connections with the data ribbon leading to the screen.
I've often seen it happen to units that were left in hot cars or attics.
Here's a great guide, from RetroFixes.com, that will, hopefully, help return the screen to normal ...
Once you have the unit apart, you'll be able to line up the screen again. Just be sure to verify that it's straight before completely screwing it back together.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ivan Meo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 836
