Zum Hauptinhalt wechseln
2,5 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,1 GHz) mit 3 MB geteiltem L3 Cache.
261 Fragen Alle anzeigen
Sound distortion from the speakers on MacBook Pro (Retina Late 2012)
So I have this MacBook Pro for about 2 years and it seems that both of the internal speakers are providing distortion to the point that I can't even use them anymore I have to use the equalizer to turn the bass all down so that I can hear it a little.
I read a comment somewhere that they can be fixed without needing to replace them. I wanna know if there is the guide or a way which I can follow to try to get them fixed without needing for expensive replacement as it seems that both of the speakers required replaced or fix.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Hi,
Any did you find any work around?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
See if the problem persists if you log on as a guest user when booting up and let us know.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Problem still persist. The sound even distort when its botting up. That means its not the software problem. Moreover I have tried reseting the SMC and P. Ram but this problem remains the same. I'm sure that its the speakers causing this.
von
Antwort hinzufügen
azn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 2,114
