Zum Hauptinhalt wechseln
HD action camera with touchscreen LCD, released October 5, 2014.
87 Fragen Alle anzeigen
Image sensor replacement fixed freezing but now back Lcd won't work!
My Gopro Hero 4 was freezing after about 10-15 seconds and wouldn't show anything but a black image on the LCD. ( I could go through settings and everything just had black image. So I replaced the image sensor and it quite freezing and takes video if I use front screen, but the back LCD appears to be receiving no power because it won't even light up now. Does anyone have any ideas of the possible problem? I checked the 3 power supply ribbons and they seem to be in place.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Was your LCD display working before the sensor replacement? I would double check to make sure the cables connecting the display to the control board are not damaged and the connector tabs are pressed down. If anything, try leaving the camera partially disassembled and wiggle the LCD cable lightly. See if the display does anything. Good luck!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Yes it did work before but thanks i will try that!
von
Antwort hinzufügen
Jordan Fujan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 261
