iPhone won't charge after battery replacement
Hi All,
Have had a couple of strange issues, I thought I'd check in with the community and see if anyone has experienced them..
An iPhone 6S and an iPhone 7. Presented as battery replacements. After replacing the batteries, the phone would charge as normal. However when the phone goes flat, it won't charge anymore.
Battery life was as expected of a new one.
Ist dies eine gute Frage?
16 Kommentare
Hi, I’m having this issue, I have iPhone 6 I replaced the battery, and it won’t charge, but if I put the old battery back in it charges fine. I’ve tried 2 different batteries incase it’s that, the battery will charge in a different iPhone, I’ve changed leads, plugs everything, just can’t get a new battery to work in the phone?
von Cara williams
Hi, I have the same problem with an iPhone SE. Tried three batteries, none charges. Coconut Battery says the capacity is only 100mAh :(
von ashra ivy
Hi Ashra,
On the SE there are tiny capacitors to the right of the battery connector. Theres a very good chance you've knocked one off. I only know because Ive done it.
You can send it to me and I'll fix it (Australia). Or find another competent microsolderer somewhere closer.
von Aaron Moffatt
Hi Cara, as discussed above, its probably TriStar related.
A way to confirm it's TriStar is to plug in a usb amp meter ($5), without a battery connected. If the phone draws 0 amps constant, your TriStar has failed. If it fluctuates between 0.01-0.08 your tristar is probably OK.
I can help with this repair or you can find a competenf microsolderer somewhere closer to yourself.
von Aaron Moffatt
@moffit I checked, there are two of these in place. If two is all. But on a video it seems there must be four of them :(
BTW, sending the iPhone from Germany around the world cost probably more then a new (used) one. But thanks for the offer.
von ashra ivy
11 weitere Kommentare anzeigen
