Zum Hauptinhalt wechseln
The Zoom Q3HD Handy Video Recorder is an audio and video recording device.
Unit records only a couple minutes, then says card full
Records only a couple minutes, with a brand new card, then says card full.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @smokn6string ,
Has it worked OK before using the same capacity card as you are trying to use now?
Has it got the latest firmware installed?
War diese Antwort hilfreich?
Bewertung 2
I believe this SD card was ONCE  formatted by a different unit than the Video Camera.   IF you have a  SD card formatted , let say by your computer, even you format it again with the video camera, this card will NOT work on the video camera.  It will work for half a minute and indicated NO SPACE, card full.  That means the SD card cannot be formatted by anything BESIDES the video camera
Bewertung 0
Antwort hinzufügen
Tom McMillan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 277
