Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2419 Fragen Alle anzeigen
Did they definitely replace the battery?
Hello all,
I took in my iPhone 6S to the apple store for battery replacement today.
I handed my phone to them with about 23% battery charge.
I received it back with 26% battery charge which seemed rather odd, the assistant did not know why but said it was fine.
I checked the Battery Health (beta) and it says "Maximum Capacity 100%"
Does this mean they definitely changed the battery? or can they just reset the battery statistics so it says "Maximum Capacity 100%"
My battery wasn't completely shot before so I'm not sure whether it will be obvious to me just by using it.
Thanks!
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Did they do the repair for $29?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Having the battery capacity being 100% means that they definitely replaced your battery. The longer you have a battery the lower the capacity will go down, so your new battery showing 100% capacity is exactly what you want. I'd recommend calibrating your battery by letting it drain to <10% then charging it all the way to 100%.
War diese Antwort hilfreich?
Bewertung 2
Hello Mike,
Thank you for your question. For safety reasons, batteries are best changed at low capacity. Having the battery read very low (in this case 26%) after it is changed is most likely a sign that they were following best practices during the repair.
Also, good job in opting for replacing the battery rather than replacing the device.
Bewertung 0
Antwort hinzufügen
Mike wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 83
