Zum Hauptinhalt wechseln
Released in May 2015 with a model number of CMP773 and a 9 inch screen.
1 Fragen Alle anzeigen
Why won't my tablet turn on after I replaced the screen it was working
My daughter cracked the screen. I replaced it. It was working I tried some apps it was charging then my daughter got on it and it was at 12% and still on charger it went off and won't come back on it does not even show a battery symbol when charging.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@kastall you’ll have to recheck your work and see if the ribbon cables are still connected etc. There is always the possibility that the replacement LCD has failed. Also, if you have a USB AMMETER see if the tablet actually charges by pulling some amps. That would give you a pretty good indication that it is just the display that is not working.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Karen Wolfe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 70
