Zum Hauptinhalt wechseln
Der Mac Pro (Anfang 2009) kam im März 2009 auf den Markt. Er führte erstmals die Nehalem Architektur von Intel in die professionelle Apple Desktop Reihe ein, und verfügt über ein leicht neu konzipiertes Inneres, das auch bei den 2010 und 2012 CPU Updates beibehalten wurde.
201 Fragen Alle anzeigen
Mac Backup Software -Backup 2 internal HD's scheduled full/incremental
Hi,
Can anyone recommend good Mac Backup Program to backup 2 internal hard drives in Mac Pro. Time Machine only backs up operating system drive and can't specify other internal drives/folders.
It needs to be scheduled and do full and incremental backups of the 2 internal hard drives to an external hard drive.
Any suggestions much appreciated :)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Since you need to schedule the backups at a specific time frame the best option would be Carbon copy cloner. The app is $30 but you can schedule backups anytime and it has alot more options than Time machine.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
So with Carbon Copy Cloner you can just backup certain folders from various internal/external hard drives without the need to do clone backup?
von
I would recommend a proper backup app ‘Cloning software’ is an imager app that makes a full image of the drive (partition) to a second drive so all of the data is moved en-mass to the second drive. This is very heavy processing wise and can wear the drives if used as a backup solution daily!
von
Here’s one app: Get Backup Pro It offers a full suite of options.
I prefer syncing apps which are much lighter in process load and take a lot less time! This is what I use: File Synchronization. I have a Mac mini which is my server which all my systems use for a backup end point. I have folders which are unique to a given system and other folders which have the same data across all of the systems. I’ve been using it for a few years so I’m invested to it.
I still use TimeMachine for a backup of my basic system config so if I kill my systems boot drive I can rebuild quickly.
Bewertung 1
Antwort hinzufügen
Adrian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 35
Letzte 30 Tage: 45
Insgesamt: 1,197
