Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Repair and disassembly guides for desktops manufactured by Acer.
51 Fragen Alle anzeigen
Windows 7 reset password/log in
I forgot the Windows 7 log in password to my Aspire AM3900G. How do I override it with out the reset disk?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
3 Antworten
Use laze soft password recovery, this tool won't give you your old password, however, it will completely remove the password, allowing you to create another one. All you need is a USB flash drive with the software installed, then boot up off of the USB from the boot menu on your computer.
Download
War diese Antwort hilfreich?
Bewertung 0
you can reset Windows 7 password with '''++Chntpw++'''.
It will be a little complicated. And also, you can use the professional tool like iSunshare Windows Password Genius. It can help you to create a recovery disk on any other accessible computer . Then you can reset Windows 7 password easily. But it will not help you find back the previous password.
Bewertung 0
Hello,
Firstly, you can try to boot Windows 7 in Safe Mode. When the login screen appears, if there is an administrator account is displayed beside your admin account, click it to sign in without password. So you can reset any other user account password in control panel after logging. Steps can be found here: Reset Acer Latop Password Windows 7 in Safe Mode.
If you cannot log on Windows 7 via Safe Mode, you can use a Windows 7 install disk to copy cmd.exe and rename it to sethc.exe, then open it from Windows 7 login screen. So you can reset Windows 7 password by using command line.
Bewertung 0
Antwort hinzufügen
Andy wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 170
