Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
LTE Version des iPad Mini 2. Angekündigt am 22. Oktober und erschienen am 13. November 2013. Das iPad mini 2 bringt die Pixelanzahl des iPad Air auf nur 7,9 Zoll unter.
56 Fragen Alle anzeigen
Can anyone please you help me with my ipad display?
The 1/4 th part of my i pad is working great but the remaining 3/4 is having small gey lines and some flikering .
the screen is not broken at all
Should i have to replace my screen or is this because the components are not intact.
Can anyone please suggest the best way in which I can repair it.
Please help !
[http://|https://drive.google.com/file/d/0B8nrv2Q...]
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Look like a bad connection, but if you have never replaced the screen there should be no reason it is not seated right. The LCD panel may be damaged, from anything. They are very fragile.
Here is the LCD for iPad Mini 2
new adhesive for the digitizer click Here
If you crack your digitizer getting it off or want to buy a new one just in-case you can get that Here
But it could be that the LCD connector is not seated right, open the iPad and check that it is fully seated before you order parts. But you will need new adhesive if you do open it.
Hope this helped you, keep us updated.
Cheers
Noah
iPad mini 1/2 Screen Digitizer Bild
Produkt
$44.99
iPad mini & mini 2 Adhesive Strips Bild
Produkt
$6.99
iPad mini 2/3 LCD Bild
Produkt
iPad mini 2/3 LCD
$99.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
dinesh reddy wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 28
