Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
794 Fragen Alle anzeigen
MacBook Pro exposed to inverse current
The power cord for my MacBook pro had broken again - the wires connecting to the converter were worn out - and I was reconnecting the wires. I'd done this repair a few times before so it was a routine process for me. Unfortunately, i was quite dimwitted when I was doing it this time and connected the white wire to the black one and vise versa. I plugged in the magsafe to my laptop with the wires crossed and exposed it to reverse current. Now my computer will not accept a change. The magsafe lights do not turn on when plugged in (with the power cord wires connected in the correct way. I tested the power cord on my brothers laptop and it works) so the issue is with my laptop. I immediately thought resetting the SMC settings would fix it but I've had no luck with that. The computer has been my trooper for the past 7 years still works fine aside from not being able to accept a charge. Any ideas on a repair? Thanks!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thanks Noah! I ordered that part and will let you know if it fixes the problem.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Oh my goodness so sorry to hear this! Those Mag Safe chargers are so expensive I have also fixed a few over the years. Now, this is probably a isolated incident only affecting the DC-In module.
I suggest you go Here to buy a new one and replace it.
The guide for that is Here
Hope that fixes the problem, though I don't believe it would spread any further than that module.
Hope this works for you, keep us updated.
Cheers
Noah
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Bild
Produkt
$9.99
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Noah,
Thanks for the fix! I'm happily typing this on my newly charging MBP!
Andy
von
Antwort hinzufügen
Andy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 53
