Charger port works but wont hold my chager cable
My phone charges but wont hold charger cable in slightest movement it comes unplugged
Ist dies eine gute Frage?
LG Tribute uses Micro USB cables. Assuming you have tried another cable, (where the most common cause of this symptom is the teeth in the cables being worn down), you could have a different issue
Your Port may be dirty inside: if pocket lint gets inside your charge port, plugging in the port will just shove it to the back. repeat this a few dozen times, and you can easily have a block in your port. A good cleaning should fix this issue.
Your Port may be worn: The ports hold the cables in strictly by pressure, and the teeth mentioned above. if this pressure loosens, which is natural over constant use, then it will stop holding a charging cable. at this point, replacing the port would solve your issue.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 262
