Zum Hauptinhalt wechseln
Das Galaxy S7 Edge ist die Variante mit gekrümmtem Bildschirm von Samsungs 2016 Flaggschiff-Smartphone, dem Galaxy S7. Angekündigt im Februar 2016 und am 11. März 2016 veröffentlicht. Modell SM-G935.
368 Fragen Alle anzeigen
Why is my galaxy s7 edge making a weird sound?
I haven't had anything happen to my phone but here lately the volume cuts in and out while watching YouTube or Netflix and it will make a random popping sound when I'm not using it. It's also overheating often.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Some possible issues and fixes for you.
1. Do a software update, this is found under General settings normally.
2. Update YouTube app and Netflix. Try a different app that would normally always have perfect sound.,Example: Pandora
3. The speakers may be going out on your phone. This would require the back glass to be removed and the speakers replaced. If I am right this will either be next to your Charge port on a flex.
War diese Antwort hilfreich?
Bewertung 0
Hello,
If this happens on different apps like Netflix and YouTube as you said, it must come either from the software, in this case veryfying if there is a new update and if not resetting the phone completely could solve the problem, or it comes from the speaker, then you will have to change it.
Bewertung 0
Antwort hinzufügen
ajnunn98 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,549
