Zum Hauptinhalt wechseln
The Dell Inspiron 14R-5437 is a desktop replacement laptop that can go the distance. With a 6-cell removable battery pack and a power sipping fourth-generation Intel Core i3 processor, the Inspiron 14R-5437 has the power to run for almost ten hours.
ripped one of two LCD cables while disassembling.
I was taking apart my laptop to get to the motherboard to replace it (if you can, can you also send a link to a decently cheap motherboard for this laptop that has at least an i5 CPU?) and while trying to remove what the tutorial said was the LCD cable, i broke the smaller of the two connectors. here is the link to the tutorial that i used: https://www.parts-people.com/blog/2016/0... The LCD cable is step 15. I was wondering if the smaller cable was necessary for the booting of the computer, or if I have to find a way to get the cable to work again.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Leveler02 Gaming,
In the picture you described there is only one cable which they are uninstalling , and this is the LVDS cable which sends data to the display. This would be necessary to use the built in display in the laptop.
I hope this helps,
Charlie B
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
the other connector is hidden by his hand
von
was anything connected to that connector?
von
Antwort hinzufügen
Leveler02 Gaming wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 264
