Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
Buzz sound in call after dock assembly change
Hi,
I replaced my dock assembly on my 3GS as the speaker stopped working.
After replacing it I found that I couldn't get a signal. I then took the antenna from the original dock assembly and swapped it with the dodgy one from the new dock assembly which fixed the no signal issue.
But, now every time I am on a call I can hear a buzz in the speaker and the person on the other end can also hear this.
Can anyone suggest what may have caused this?
How can I fix it?
Thanks!
Update
Must have been some sort of a grounding issue.
I ended up soldering the new speaker to the original dock connector/mic and attached the original antenna.
It's all working perfectly now.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Its most likely a grounding issue. With out a proper ground (your hand or any other conductive material thats connected to the ground) you will get a buzz. This is known as a ground loop hum. See if there are any bare wires that are touching something inside. The best place to look is near the microphone.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
not a whole lot of wires inside the iphone ;-( but make sure that you triple check your work on the dock connector and make sure you did not create this issue with your repair.
von
Antwort hinzufügen
Wizzzz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,084
