When you restart a Microsoft Office program after a power failure or similar problem, the program automatically opens any recovered files. If for some reason the recovery file didn't open, you can open it yourself.
1. On the Standard toolbar, click Open.
2. On the Show pop-up menu, click All Documents.
3. Locate the folder that contains your recovery files.
Each recovery file is named "AutoRecover save of file name."
4. Open the recovery file.
5. Click Save.
6. In the Save As box, enter the name of the existing document.
7. When you see a message asking whether you want to replace the existing document, click Yes.
Any recovery files that haven't been saved are deleted when you quit WordTips
• If you can't open the recovery file, you can try to recover the text from the damaged file.
• To find out or change where your recovery files are stored, click Preferences on the Word menu, and then click File Locations.
• Or you can try to use PAID service , repair word document , find solution here . I wish you Good Luck !!!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
