First, for the sake of it, go to this page on the Apple website and input your serial number. You may be eligible for a free battery replacement.
As for your battery health, try to put the iPhone in restore mode. Leave for 5-10 minutes, then force restart it and see if it identifies the battery.
- To put it in restore mode: turn it off, press and hold the home button (for the 6S or older models; newer models require a different approach); while holding the home button, plug the iPhone in your computer. The iPhone will restart and show a cable on the screen.
- To exit restore mode / force restart your iPhone (6S and older): press and hold power button + home button until the iPhone turns off then back on and the apple appears on the screen. Then release the buttons and wait for it to finish starting up.
A word of advice: pull a back up before doing this procedure in case something is messed up and you brick the software. You could always restore it, but your data will be lost if you don't have a recent back-up.
Let us know if this helps.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
