Zum Hauptinhalt wechseln
4-Zoll iPhone herausgebracht im März 2016 mit ähnlicher Hardware und Spezifikationen wie das 6s. Erhältlich in Silber, Space Grau, Gold oder Roségold mit 16/64 GB Speicher. Modell A1662 und A1723.
1049 Fragen Alle anzeigen
New Battery Pack doesn't charge
Hello
I replace the Battery as described. I Icon show the Battery will be chardged but it sucks on 1%
Any Idea what went wrong?
Regards
Gérard
Update (06/25/2018)
The part most right of the connector is missing
The spudger of ifixit isn't the correct tool. The fingernail is a better tool!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hello
The situations is more strange as thought. The iPhone was charged now for more as a night and it displayed it was only charged with 1%
I left the iPhone on my desk and took my old iPhone 4S for my work. At night when I came home the iPhone SE was still on 1% without be on the charging cable. So it looks like the battery isn't communicate with the phone. All Mails during the days are loaded. The iPhone SE is visible in the Network by the DHCP Server and in iTunes (Version 12.6.2.20) I can still make a backup of it ?!?
Could it be an issue with a bad Battery Back. The Original Battery has Part 616-00107 the new one has 616-00106!
Regards
Gérard
von
Einen Kommentar hinzufügen
2 Antworten
tristar ic, it fails when you use cables that arent original or MFI certified.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
Very strange! Before the Battery Swap this cable works fine. This cable is able to charge my iPad Air 2 normally!
I charging always on the Computer. I will search for the Original USB Charger and give it another try.
Normally my iPhone SE is in an Original Mophie Juice Pack Plus. Even with the Pack (green switch) or with the Charge Cable of the Pack it won't load more as 1% (the Juice Pack is blinking so this seems to charge)
I will try to buy a new Cable in the local Apple Store but I can't image this will solve the problem
von
in that case, look next to battery connecter. There is a few very small components (caps and filters). one is for battery gas gauge and can be easily knocked off during a battery replacement.
von
hello lukerockhill
I will make a picture. propably you are right. their should be 4 components I see only 3. They are soo small. I used the original ifixit manual and the spudger of the ifixit toolbox. (Step. 12). It should be better to use the fingernails for this purpuse :-(
Is there I way to fix it? Bridge it? What component is missing?
von
dont bridge it, a capacitor goes there so you would be shorting out the line if you just connected the two pads. in the picture i think i see the cap that fell off touching the other component to the left of where it was. try to remove it and see if it works. alot of times caps are there just to smooth out the power and will work still when one is removed. but the component it seems to be touching is a filter for battery gas gauge.
von
Try to charge the battery with the phone off.
Bewertung 0
1 Kommentar:
I tried this also without success!
von
Antwort hinzufügen
Gerard Dirks wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 146
