Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
Front panel replacement,iPhone 6s Plus
Not sure what driver is required for all screws I have got #000,#00,#0 and #1 Phillips driver however not all fit.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You will need a Pentalope screw driver it's like a torque driver just a bit different you will get one in the kit if you buy the kit with the tools. There are only 2 Pentalope screws they hold the front screen to the housing. You will need a suction cup and a hair dryer or an adjustable heat gun or s small sock with rice in it. The glue on the front housing will loosen easier when it is heated but don't heat it too much you can mess some things up by over heating your screen.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
It’s not for opening the phone it’s for the screws in the bracket there is three different sizes of screws 3x1.2mm , 1.6mm and 3mm screw I think?
von
I pretty much use a 1.5 X 25mm driver for all the screws inside of any iPhone except for the 7 and above you will need a different driver. Look at the head of the screw make sure it is a "+" and not a "y". If it is a "y" you will need a y0.6 driver for that screw
von
Antwort hinzufügen
Andrew Girvin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 42
