Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
421 Fragen Alle anzeigen
Topcase exchange US -> EUROPEAN
Hi everybody.
Can anybody tell me how to sync a A1466 logicboard with the Topcase. Changed the topcase from US layout to european Topcase, but left Shift Key is not working.
Already tried several steps (Internet recovery, SSD from european version with OSX pre installed) but nothing solved the issue. :-/
I'm not able to change the layout from US (10 Keys between left and right shift key) to european layout (11 Keys between left and right shift key)
Thanks in advance,
Ben
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
@littlebigb - Did you also switch-out the trackpad or did you reuse the one from the original uppercase?
von
Hi Dan,
Yes, I reuse the one from the original uppercas.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you have performed all software tweaks found in system preferences/keyboard to no avail try resetting SMC: turn off the Mac, press shift+ctrl+alt+power..you'll see magsafe light going from amber to green and amber again. Boot the Mac and before the chime press alt+cmd+P+R and keep them pressed until the second chime to reset Pram. If no joy, try reseating the keyboard cable on the logic board.
If none of these work, possibly you got a faulty topcase.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
+1 vote for faulty topcase if SMC reset does not help.. though I feel I might be missing something..
von
Thanks. I'll try it tonight. :-)
von
Antwort hinzufügen
Little Big B wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 102
