Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
84 Fragen Alle anzeigen
My 3DS won't turn on after accedently putting in the battery wrong
Hello,
during some testing with a 22.4 Amp hour LiIon battery I accidentally switched negative and positive and now my 3DS won't turn on even when I've connected it to the charger. The DSi had a fuse on the D-Board which you can replace to fix it. Is there a way for the new 3DS?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Most of these machines have both a fuse and protection diode to prevent this from destroying the device. If you are getting no power, first check the fuse. If the fuse is OK or has been replaced, move forward in the circuit looking for a diode that may now be open.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
[Sable] wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 105
