Help! I can't get the screw out!
So I was screwing back the screws into the side of my MBP A1150, and I accidentally stuck one of the screws into one of the screw holes on the side of the DVI port!
I tried to unscrew it out, but that didnt work at all. The head is practically flushed with the case, so I doubt I can use a pair of pliers.
Worst case solution...drill?
Ist dies eine gute Frage?
1 Kommentar
I have the same problem. I accidentally put a screw in my monitor-input because it's exactly thesame size and I wasn't paying enough attention, obviously... tried 1 second glue on a stick but that didn't work. What about you, did you get it out? If so, what did you use?
von Eva Lindeman
