Zum Hauptinhalt wechseln
Apples Laptop-Serie für Nutzer:innen mit höheren Ansprüchen im beruflichen oder privaten Gebrauch. Bislang gibt es Modelle in den Größen 13, 14, 15, 16 und 17 Zoll. Die wichtigsten Entwicklungen gab es beim Prä-Unibody (Original), Unibody, Retina Display, Touchbar und SOC (system-on-a-chip) Design.
19981 Fragen Alle anzeigen
Help! I can't get the screw out!
So I was screwing back the screws into the side of my MBP A1150, and I accidentally stuck one of the screws into one of the screw holes on the side of the DVI port!
I tried to unscrew it out, but that didnt work at all. The head is practically flushed with the case, so I doubt I can use a pair of pliers.
Worst case solution...drill?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I have the same problem. I accidentally put a screw in my monitor-input because it's exactly thesame size and I wasn't paying enough attention, obviously... tried 1 second glue on a stick but that didn't work. What about you, did you get it out? If so, what did you use?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I had this issue too :( The screw head is almost exactly the same size as the hole for the dvi which makes it very stubborn to get out! The only way I was able to get it out is by removing the top case (keyboard and trackpad) and then using two small thin needles. One needle to slip in between the case and the dvi receptacle while using the other needle to manipulate the head of the screw. After about 5 minutes of finagling I was able to get it out! I hope this never happens to anyone else but thought I would post my experience in case anyone else finds it useful.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Go to the hardware store and get a very small easy-out. Chuck it in a drill and set to reverse. Use a very slow drill speed and it should screw out.
Bewertung 5
2 Kommentare:
The screw isn't actually on any threads...it's just jammed in because the head fits perfectly into the DVI screw hole.
von
In that case I would use a magnet to pull it out or if that doesn't work try gum or some other sticky substance on the end of the screwdriver.
von
Antwort hinzufügen
iChun wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,038
