Zum Hauptinhalt wechseln
Das Huawei P8 Lite (Modell: ALE-L21) angekündigt im April 2015, verbindet Schönheit mit Schlichtheit. Seine professionellen Kameras ermöglichen es dir, selbst in der düstersten Umgebung natürliche und scharfe Fotos zu machen. Der Beauty Modus hebt die schönsten Seiten des Eigentümers in jedem Selfie hervor.
110 Fragen Alle anzeigen
Dropped my phone in sea. help! CAN FIX IT AFTER 15 hours?
Hey guys yesterday my phone dropped in a gulf at midnight...if I swim at the morning and I can take it. It is 1.40 m from the ground
Update (07/12/2018)
I disassembled all in the phone expect the lcd and ear vibrator. . I have to roll it off completely or I can drop it with the pieces in the liquid you told me about.
And correct I am from Greece..also The battery is for rubbish now
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you're in Greece as your name hints to, it's just a pleasant swim right now, pretty hot here in the Med ;)
Nobody knows what happens to a submerged phone, but if you fish it out don't try to turn it on and don't put it into rice. Remove the logic board following the guide, put it into Isopropyl alcohol and let it soak there for an hour, then remove it and brush it with a soft toothbrush and let it dry for a day. Meantime buy a new battery and then try your luck, reassemble everything and hope for the best.
Huawei P8 Lite Motherboard ersetzen
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Thanasis Katsoydas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 193
