Zum Hauptinhalt wechseln
Angekündigt im August 2017. Das Galaxy Note8 ist der Nachfolger des durch Rückruf bekannten Galaxy Note7. Erhältlich war das Note8 im September 2017.
My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
von
Grateful it worked
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
War diese Antwort hilfreich?
Bewertung 10
6 Kommentare:
This worked for me, thanks.
von
purrrrfect solution , thank you
von
Worked for me too thanks!!
von
This worked thanks alot. ?
von
Worked great for me. Thanks!
von
1 weiteren Kommentar anzeigen
Tweezers? Here is a video of someone getting one out:
https://www.youtube.com/watch?v=zA5xYT-x...
Bewertung 1
1 Kommentar:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
von
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
Bewertung 1
2 Kommentare:
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
von
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
von
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
Bewertung 1
Along the lines of the paper clip method, I used a ball point pen ink cartridge to stick the pen tip into the remaining S pen fragment and the cartridge pulled the fragment out on my first try!
Bewertung 0
Antwort hinzufügen
Robin Kamps wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 32
Letzte 30 Tage: 153
Insgesamt: 24,598
