Zum Hauptinhalt wechseln
1,86 GHz oder 2,13GHz Prozessor, 128 GB oder 256 GB Flashspeicher
147 Fragen Alle anzeigen
Trackpad and Keyboard ghosting
Since some days my MacBook Air 13 Inch Late 2010 has a problem.
Both the Trackpad and the Keyboard do some entries without typing or clicking anything.
Its like somebody types on my keyboard or uses my trackpad without any physical input.
I wonder if the problem is not the keyboard or trackpad itself because both of them started to act weird at the same time.
Is there maybe a cable that could be responsible for this?
Would be glad if someone ever had the same problem and hopefully a solution.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yours system uses a single cable to send the keyboard & trackpad signals to the logic board. What can happen is the battery swells pressing on it. I would first recommend checking your batteries health using CoconutBattery paste a screenshot of the apps window here for us to review Bilder zu einer vorhandenen Frage hinzufügen depending on what this shows you’ll likely need a new battery. MacBook Air 13" Ende 2010 Akku austauschen
Another source of problems is the trackpad its self as its the junction point for the cables. a liquid spill can mess up the trackpad or if the liquid gets to the back side mess up both. At this point you’ll need a new trackpad and you may want to replace the cable as well. MacBook Air 13" Ende 2010 Trackpad austauschen
MacBook Air 13" Late 2010 Akku Bild
Anleitung
Schwierigkeitsgrad:
Mittel
15 minutes
MacBook Air 13" Late 2010 Trackpad Bild
Anleitung
Schwierigkeitsgrad:
Mittel
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Hello Dan
Please check the screenshot attached :)
von
It looks OK, you'll need to replace the trackpad & its cable
von
OK and you are sure that its not only the cable but also the trackpad? How is it possible that also the keyboard acts so weird? :(
von
OK, Lets think it like this: A cable to B cable to C where A is the keyboard and B is the trackpad and C is the logic board.
So A & B can encounter problems if the cable between B to C is bad. Its also possible A and B can encounter problems if B its self is bad. Does that help in visualizing the issue?
We are replacing the two elements that can effect both the keyboard & trackpad.
von
Antwort hinzufügen
jimmy industries wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,535
