Zum Hauptinhalt wechseln
Die Nintendo Switch ist eine tragbare Spielekonsole, die auch mit dem Fernsehgerät verbunden werden kann. Sie wurde am 3. März 2017 veröffentlicht.
464 Fragen Alle anzeigen
My switch has no audio. Possibly due to water damage.
Speakers only make static. Nothing out of headphone jack. Do I have to replace my whole motherboard to fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
The earliest i could take it to a repair center would be in a few days. How much of a problem would this be?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
As you know liquids and electronics and electricity are not a good mix.
The liquid causes corrosion and provides circuit paths for the electricity which were not in the console's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
The water may have damaged the audio controller or some other parts of the console.
First do not turn on your console and then you need to remove the battery as soon as possible from the console to minimize further damage.''
Then you need to dis-assemble the rest of the console and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Once you have properly cleaned and dried the console you can inspect it more closely to check for any obvious damage to the components.
Here is a link to the ifixit Nintendo Switch Repair repair guides which may be of some help.
If this process seems too daunting, take your console to a reputable, professional electronics repair service experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
Hi,
If you can, remove the battery from the console and obviously don't try to turn it on with power connected to it. This will help to minimize any further damage until you can get it looked at..
von
Antwort hinzufügen
Ethan Thomas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 11
Letzten 30 Tage: 23
Insgesamt: 1,725
