Zum Hauptinhalt wechseln
Can be used as a space heater or decoration.
Is This Safe To Plug Into an extension cord or power strip?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
How many AMPs does it pull?
von
Einen Kommentar hinzufügen
2 Antworten
Hi @bunnybunny
Use the below link for a gauge.
https://www.electricalsafetyfirst.org.uk...
For safety , do not overload those.
War diese Antwort hilfreich?
Bewertung 0
Typically for this type of device, it is not recommended to use any type of extension cord. If you must use one due to placement for safety, use one rated for the current required by the fireplace. This should be marked on a plate on the back. If in doubt, use a cord with a higher rating. In other words, if this is rated to use 15 Amps of power, I would recommend at least a 14 gauge extension. Better still would be a 12 gauge.
Keep the extension as short as possible too.
Check with the local electrical inspector as well. Sometimes, insurance won't cover a loss if something is done counter to standard practice or recommendation.
Dan
Bewertung 0
Antwort hinzufügen
Jacob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 392
