Zum Hauptinhalt wechseln
ASUS Chromebook Flip C100P was released in 2012. This was the first-ever 10-inch convertible Chromebook released. It is a laptop running Google's Chrome OS. The C100P came available with 2GB or 4GB of RAM, and silver as the only color option. Repair of this device requires screwdrivers and prying tools.
20 Fragen Alle anzeigen
Cracked screen making it hard to use.
I have a pretty big crack in my screen....no dead pixels, but it's making the touch screen go crazy. I can hardly use the chromebook even in laptop mode because the screen will flicker and open random things as if someone is going crazy on the touchscreen.
I looked into ordering the screen repair kit but found it was almost as expensive as a new chromebook. So my question is, is there a way I can just disable the touchscreen function? I don't mind only using it in laptop mode.
Thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
steph fxe this should work for you
First go here: chrome://flags/#ash-debug-shortcuts and enable the flag, then click RESTART NOW at the bottom of that page.
Once that's done, you have two new keyboard shortcut toggles available to you -
Toggle touch screen on/off: --> Search+Shift+T Toggle touchpad on/off: --> Search+Shift+P
WARNING - use of this feature may cause unwary users to think their touchpad or touchscreen is defective. There are no status indicators to tell you that you have turned the touch device off!
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Alright! thanks so much, I never would have figured that out by myself. You just saved me a bunch of money, awesome.
von
Antwort hinzufügen
steph fxe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 2,029
