Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2686 Fragen Alle anzeigen
tigris or tristar? ( how it works ) some strange problem
hello,
in facts:
iPhone 6s, no water damage, all is fine but... After every 5 minutes, when screen is off phone is going to kind of loop. Current consumption drops to 0,58-0,62 and oscillating on these values. Nothing work, just hanging. Disconnecting the battery is only helps.The same when charging by wall plug. The exception is when charging by usb (computer).
Questions:
how it work?
When phone works normally, power supply is implemented by PP_BAT_VCC to Tigris Chip (U2300) which is responsible for generating PP_VCC_MAIN. If the Lightning port is connected, (then Q2300 is "opens") and PP5V0_USB is used to generate PP_VCC_MAIN.
In my case, it looks like Tigris is not working properly. But when "hanging" PP_VCC_MAIN is ok (approx.V=4,2). This leads me to suppose that the circuit PP_BAT_VCC is damaged (somewhere).
Can anyone explain how the PP_BAT circiut works? (in logic)
- thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
finally, the expected reply after almost four years.
PP_Bat supplies a constant voltage of 3.8 V to the main charger code Tigris (TI 56AX531). To this day, little is known about this device, apart from a few clichés, it is necessary to run the entire electronic system due to its connection to key control lines. The device can be deceived by supplying to the 3.8V line from any generator. In this case, due to the lack of readable information for the sensors, the system resets itself in counted time units. Due to the above, do not look for a fault in the battery itself and the PP_BAT installation, the above implications can be easily ruled out.
My problem was the low resistance of the relay power lines for the i2c * AP data and _clock control lines in a completely different subsystem, also using 1.8V boost for the sensor system but that's another story.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Hi @tojaert, how do I ask you a repair question? Sorry I can’t work out how to contact you.
von
@kathy57552
good morning, Hi. You can use the link in the "about me" tab - there you will find the address to my blog, dedicated to Apple repairs (there is also an email address there). You can also post your question in a new thread here on iFixIt and tag me @tojaert - I will get a notification from the system :-)
- regards,
von
Change tristar fault seems to like.
Bewertung 0
1 Kommentar:
no, tristar had nothing to do with it, it is responsible for completely different tasks.
von
Antwort hinzufügen
bert.harmidomski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 552
