Zum Hauptinhalt wechseln
Hybrid laptop/tablet manufactured by Microsoft. Released October 2015. Model 1703.
83 Fragen Alle anzeigen
Suraface book battery 2 not charge
this computer has two batteries (1), one in the screen and one battery (2) in the keyboard, for about 3 days the battery 2 does not charge, I tried to remove the battery drivers (device management) and keep the access key pressed and high volume for 30 seconds but the problem continues to show up. At the moment I have to keep the PC connected with the power cord or it goes off after about 40-50 minutes. Does anyone know how I can solve this problem?
Battery report:
http://i68.tinypic.com/6ynkp2.jpg
http://i63.tinypic.com/27zdpxx.png
Thanks for all help
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
I managed to figure this out for myself after trying every solution including the power plus holding the volume up button, booting to UEFI, nothing happened there. I reset the whole laptop to factory settings, nope still not fixed. I changed the charging cable, nothing. I removed drivers for keyboard, batteries. Ran windows diagnostic, nothing. I didn’t give up though as I paid $1800 for this laptop and in now in the U.K, and an expired warranty, I couldn’t do anything about it.
The only solution that worked was to let the whole laptop battery discharge to 0% and shut off, then close the lid, charge it overnight and in the morning I was amazed when the keyboard lights came on and the detach function began to work. I am not sure therefore, if this is indeed a hardware fault of something in the software conflicting with the charging of the base. As long as I keep the power in and keep the keyboard battery above 50%, it doesn’t happen anymore. Maybe this will help someone else.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you!!! I was this close to paying $599 to send it to depot repair and this fixed it!!!
von
Draining power completely is a "fix" for automobiles (disconnect the battery and turn on the headlights, ignition switch to "run" and any devices related to the problem ) , laptops and desk tops (back when you could remove the laptop battery with the incredible thumb, or yank the cord from the desk top - or the Tandy Corp. under the desk unit.
von
I am very reluctant do do this, as I get the impression from many reports that fully discharging the (keyboard) battery is what first starts that whole problem for most users. OTOH, as the computer does NOT drain the keyboard battery in this state, that may indeed force the system to look for power elsewhere.
Willing to give it a try, because as is my keboard is bricked (at least as the main battery; the keyboard as an input device works.)
von
Just call Microsoft, this can only be handled by warranty support, for free.
Bewertung 0
3 Kommentare:
unfortunately the support via chat with them has expired recently because my guarantee has just ended a few months ago. For that I hoped that someone with the probelma similar to mine had found an alternative solution
von
There is no solution other than replacing the battery, sometimes even repairing the board because there could be something wrong with the charging circuit.
von
this is really absurd when this PC recently used it and has not even done 200 cycles of recharge for the battery 1 and 2
von
It was really helpful
Bewertung 0
First before charging on the dock or cable remove keyboard. Everything else will help after that. QDJR
Bewertung 0
Antwort hinzufügen
alberto hotmail wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 12
Letzten 30 Tage: 60
Insgesamt: 8,343
