Zum Hauptinhalt wechseln
Das Galaxy S7 Edge ist die Variante mit gekrümmtem Bildschirm von Samsungs 2016 Flaggschiff-Smartphone, dem Galaxy S7. Angekündigt im Februar 2016 und am 11. März 2016 veröffentlicht. Modell SM-G935.
369 Fragen Alle anzeigen
Loudspeaker hissing and "snow" noise
Repaired a customer’s S7 Edge screen and the loud speaker stopped working. Customer brought phone back when the new part came in and I noticed when it was dropped off that the loudspeaker was making a hissing noise and sounded like snow on a TV. After replacing loudspeaker, the problem did not go away. I had a spare S7 Edge at the shop (as all it does is bootloop), took the loud speaker out of it, and tried the 3rd speaker with customer’s phone- same problem.
Everywhere I look, the answer seems to be software/app related. I looked at the board, and compared it to other boards. No signs of a burn or short or missing chip/bent prong, etc.
So, to recap, his original speaker stopped working after screen replacement. He took the phone with him until parts came in. When he brought it back, the loudspeaker was making a hissing noise. Replaced loudspeaker with new part- still hissing. Tried another part from a different source- same problem.
Any suggestions?
Thanks in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hello,
The only cause I can see is either a software problem, then maybe a factory reset could help, or a component from the motherboard that is causing this problem.
I hope it helped you a bit
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Trevor Brodie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 304
