Blue lines in de top corners of my screen
There are blue lines in the top corner of the screen. What is causing this and what can I do to make it better?
Ist dies eine gute Frage?
Frits you can’t fix this. This is a failed panel. The only way to repair your TV is by replacing the panel. These will be hard to find. Remove the back from your TV and take a look at the panel. There should be a label which identifes the maker (Vizio is not choosy, they use anybodies panel) and the model of the panel. Use those numbers to try and find a replacement
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 200
