Zum Hauptinhalt wechseln
Hier werden Fragen rund um die Computer-Reparatur beantwortet.
21245 Fragen Alle anzeigen
Disk usage 100%, nothing running
So task manager shows my disk usage is 100%. I am currently not doing intensive pc work. What is causing this problem and how can I fix this? Screenshot included
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I have a Alienware x51 R2
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Had this problem on a number of computers running Windows 10.
Current (March 2019) Windows 10 Updates fixes most of this high drive activity.
Spy-Bot’s Anti-Beacon software will block most of MicroSoft’s snoopy telemetry software which also causes much drive activity.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
This is very common in windows 10. I wasn’t happy when mine was doing this so i installed an SSD. Problem solved
Bewertung 1
1 Kommentar:
Everything worked well before, a couple of months now my pc is getting slower.
von
The computer is busy because Windows 10 is doing one of its many updates. Currently (2018) the only easy workaround is : let it run some hours while you are away…
For more help, you may read “Why are Windows 10 updates so slow? “ (may 2018) : https://www.techadvisory.org/2018/03/why...
Bewertung 0
How to protect computer from cryptojacking
https://techfordaily.com/how-to-protect-...
Bewertung 0
Antwort hinzufügen
Ruben Debbaudt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 568
